Spring leaf bushing bolt sizes
porkysplace
1,493
mid- michigan
Can someone tell me the bolt sizes for the spring leaf bushings?
What is the NSN number ?
M1008 or M1009 ?
___________________________________________________________________________
Edit;
M1009 part #'s
Front bolt : MS90728-152
Rear bolt :
MS90728-150
TM9-2815-237-34.pdf
TM9-2815-237-34 Direct and general support maintenance engine 8 Cyl diesel naturally aspirated water cooled.
cucvrus
10,434
Jonestown Pennsylvania
I think the spring bolts are all 9/16" x 18 on all CUCV's. Length I don't have memorized yet. But the front shackle bolts are 7/16" x 14. Good Luck. I know the spring companies have all that information.
cucvrus
10,434
I think on the front axle front bolt. But I think the rear axle springs may be 4 1/2". I don't have total recollection. Good Luck. I think M1009 and M1008/M1028 are all the same.
319cssb
221
Easley SC
Front spring shackles. I don't think so. I cut them and put them in the other way. They work the same. Been there. Done that. Good Luck.
I know that was my plan but, funny story.
i put the 7/16 grade 8 bolt in the shackle in the driver side. Torque to 50 ftlbs and it got really easy on me. First i thought thr poly bushing wasnt seated right. But it turned out the nut stripped. Had a good time cutting them off. Put the old bolts in and torqued them to spec - no problem. So now i want to get a OEM grade 5 bold before cutting the old one.
i thought fastenal would have good quality stuff.
