4l80e stand alone controller wiring harness
kfrosty
Belmont, NC
I've been trying to search and haven't found a resounding answer. We're getting some 6.5 complete drivetrains with 4L80e transmissions. We are getting the controller boxes but wiring harnesses are cut. I've read most are going with stand alone controllers such as TCI. I think I'm going with the US Shift option as they are close by.
My question is though is whether anybody has used either TCI or US Shift, if the wiring harness plugs directly into the 4L80's that come in military vehicles?
I thought they did and I've seen some that claim they don't and I'm trying to verify with 100% certainty.
Thanks
richingalveston
120
galveston/Texas
I got really screwed by tci. Get the US shift controller it is much better and easier. My install was adding a 4l80e to the 6.2 in my 1009, not a HMMWV.
TCI is crap, don't waste your money
Augi
42
SF Bay Area
If you have the large harness connector on the military TCM, you can just make your own harness. I did it and it's been going strong for years.
I got the wire from Erik's.
panzerwillie
136
miami florida
I did the swap om my M1010 with the US shift few years ago and it has being to Alaska and San Diego in those 2 convoys and works great with the US shift, the 4l80E i used came of a 6.5l truck after rebuilding with a trans go kit and deep pan has never had any problems....
kfrosty
Belmont, NC
US Shift sells the wiring harness. The question is does it plug directly into a 4L80e from a military vehicle. I thought the plug "receptable" for the harness was the same on all 4L80e's.
Dock Rocker
72
Jackson ms
I have used microsquirt shift controller in the past. It's cheap and easy, as well as computer tunable. If you guys are familiar with megasquirt this is an offshoot of megashift.
Sent from my SM-N920R7 using Tapatalk
kfrosty
Belmont, NC
To anybody answering what you used, the question still remains did the wiring harness you got plug in to the existing connector or did you have to modify it?
Thanks
BLK HMMWV
497
Pasadena California
Kfrosty
I used the TCI harness. It was several years ago.
To the best of my knowledge I had to replace the connector that went to either the throttle body / injector pump.
I can try and dig out my old harness and take a picture of the plug on the harness and see if it matches what is on a factory TCI harness.
Sorry that's the best I can offer.
I won't be able to take pictures till next week however.
Augi
42
SF Bay Area
There are only two types of connector for the 4L80e. GM and Jaguar. The military transmission uses the GM connector. It's standard and you don't have to mess with it. If you look on the stupid auction site you will find "repair harnesses" which consist of the connector with 6" or a foot of flying leads.
Augi
Jon0249
Lipan, TX
Can't answer your question, but can give a plug for US Shift. I replaced my mil TH400 with a civ 4L80e and am totally happy with it. You'll love it. Jake at USS is superb. I sent him a HMMWV profile with shift points that they'll be adding to the standard templates. Good luck.
hahnmgh63
22
Roy, WA
Old thread but I'm thinking about going with the US Shift unit. Any suggestions on options. It is the Quick 4 right? Do you need the double brake pedal switch? I have the detuned 6.5NA so I will need to add the TPS? Anything else?
Dock Rocker
72
Jackson ms
Quick 4 is correct. No pedal switch and yes you will need a TPS.
You will need to run a switched power relay so the controller comes on with the ignition switch.
You will need to find a dry place and way to mount the control software.
Do you have a trans, 4 speed shifter, crossmember and converter?
TOBASH
3,488
Brooklyn, NY
There is a post somewhere in the last 2 months where someone said they cracked the programming necessary for a stand-alone 4 speed controller.
Not sure of the computer unit he used BUT he seemed super psyched.
When I asked what he needed and installed re.: tranny parts and such, he told me it was a lot of work and he did not recommend IIRC. Jon0249 seems to have had a different experience, so ask him, although his last post was 05-31-2018.
I will be doing a 700R4 truck tranny. Not as robust but no computer gobbledeegook. As I will not be heavy duty crawling I think a 700R4 will be fine for occasional camping and mild off road.
T
hahnmgh63
22
Roy, WA
I got a used 4L80E from Eastern Surplus off Ebay with the crossmember. The guy who removed it from a cutup HMMWV was an idiot though. Tranny itself seems to be in good shape but.... Won and auction for a new Military Surplus 4L80E w/Converter from Govplanet. I'll use the new tranny & sensors and a couple brackets and crossmember from the old one. I have a new 4spd shifter, 242 transfer case, and a new rear driveshaft. Still need the front driveshaft.
My M988 has the 6.5NA from Depot but still with the 218 transfer case so I'll swap to the 242 to make it all easier. I appreciate the reply. I'd like to get it all done before summer.
Did you use the Mil TPS or an aftermarket or GM one?
Jon0249
Lipan, TX
I used an aftermarket TPS I did have to modify the cross member, but no big deal I also swapped in s 242. Nice to have the 2WD option. The naysayers warned against it, but 20k miles later, I'm still happy 🙂
TOBASH
3,488
Brooklyn, NY
I used an aftermarket TPS I did have to modify the cross member, but no big deal I also swapped in s 242. Nice to have the 2WD option. The naysayers warned against it, but 20k miles later, I'm still happy 
Does the 2wd afford any benefits or is it just there?
I posted about this and then decided against.
Curious.
T
