Air line size
USN_Green_Addict
214
Oahu, Hawaii
Does anyone know where I can find these lines and fittings? Or is there a way I can buy them pre-bent?
Sent from my LG-H918 using Tapatalk
USN_Green_Addict
214
Oahu, Hawaii
I forgot to put the rest of the post.
Went to move me truck today. I had 90 PSI of air, brakes were adjusted good. I only drove about 100 feet. Without any warning while sitting at a stop I presses in on the brakes saw steam come from the engine compartment and the brake pedal wasn't as firm as it was when I first started it up. Now when releasing the brake pedal I hear what sounds like air. I looked in the engine compartment and the air line that runs parallel with the air govenor line looks like it may have a kink. My airpack is freshly rebuilt. Any ideas of why this may be hapening or is it the possible kink?
porkysplace
1,493
mid- michigan
Doubt you will find them pre-bent , they are just copper tubing with ferals , the nut is re-usable but you will need new ferals . You could replace the with plastic tubing rated for air brakes , if you have a Parker dealer near you they should have everything or your local heavy truck parts supplier .
porkysplace
1,493
mid- michigan
Are you losing brake fluid ?
USN_Green_Addict
214
Oahu, Hawaii
Yes brake fluid is coming out the vent. Pic is of what happens when the brake is released and at 90 psi. Hard to tell without the video playing you can see it coming out of the vent. And yes air tanks were purged prior.
doghead
4 Star General /Moderator
1,179
Please attach pictures, not link them.
doghead
1,179
Your air-pack has failed.
77 AMG
62
Owingsville, KY
You might as well go ahead and replace the compressor to regulator line, and the 2 under the dash while you are there... I had air leaks at the pressure gauge AND the front axle switch. Cost less than $25 to fix them all... Air leaks SUCK. Especially on a system that uses air pressure for ALOT of things. Plus, field repair capability majorly increases with the new Nylon based lines, as opposed to the old copper stuff.
USN_Green_Addict
214
Oahu, Hawaii
Company said only 30 day warranty and offered to discount me another one for $375. It lasted January till today and 150 ish miles.
