I have a mep 803a that seems to have a flywheel problem .
When you try to start the generator the flywheel turns but the engine does not.
Does anyone know if the flywheel bolts to the crank or is it a taper and key ? Also is this a problem anyone has seen on this model?
Any info would be helpfull
Thank you
Thank you
