- 1,418
- 651
- Quantico VA
This current design I can make and sell for $40 a pair, which is competitive with other sources, except we hope mine last longer!
BDGR
BDGR
If yours just last two years they would be worth it ! I'm sure that they will last much longer though !This current design I can make and sell for $40 a pair, which is competitive with other sources, except we hope mine last longer!
BDGR
Exactly ! Also were just coming into Spring so the weather is still a little bit crappy to work outside. I'm sure in a couple of weeks the weather will start to turn for the better and then someone will need to replace their axle boots.@ Bulldogger. Don't get discouraged as most people don't want to change a boot unless they have one that is ripped. I just changed my passenger zippered, ripped boot to a silicone one piece last week. The other one is still good. BTW, are they waterproof? I drive through a lot of deep puddles and tons of mud here now that the snow is melting.
Russ, I apologize that I missed your note, as the page count for this thread jumped and I kept going.What the heck. I've never changed boots before, but mine need changing now, so I'll volunteer. I have a set I ordered from someone, but hopefully yours will be the bomb and I won't need them anytime soon.
Correct when you have the old style ball and seat CV joint not the new cross style U joints. Sometimes you have to use your head and know what, why and where to put grease. Now if you had the old style then you pull "both" plugs .Pictures for the general
The GAA outlet hole to pull when greasing......
View attachment 759245View attachment 759246
