M1101/M1102 for Alaskan expedition
djglover7
Central Texas
Forum,
A general question to start all of this (my M1102 is inbound).
Has anyone modified/outfitted and M1101/02 for a trip that will be 50/50 highway vs gravel?
I would like to get thoughts on weight/balance, fuel cans, spare wheels, etc.
I will be converting the wheels to match a 2016 Silverado 2500 4x4 (8 x 180mm lug pattern).
Dennis in Texas
Tinstar
1,738
Edmond, Oklahoma
Search the old threads.
A lot of guys have done some amazing camper/expedition builds with these trailers.
Very ingenious ideas to utilize the space available.
Some use the S-250 shelter and others build their own.
As mentioned, the trailers are WAY overbuilt and can handle a lot more than a civilian trailer of same size.
djglover7
Central Texas
M1101/M1102 canopy base question
Forum,
I will be taking possession of a late model M1102 next week. I need to provide a set of towing taillights and tow it approx. 75 miles. I currently do not have access to the trailer.
I have a tow light setup but I would like to bolt it down to the corners where the canopy base attaches (crimped nut inserts facing UP). Does anyone know the thread pitch?
Thanks in advance,
Dennis
porkysplace
1,487
mid- michigan
Forum,
Thanks in advance,
Dennis
Get the NSN or part # from the TM (in the trailers section of the TM forum) and run the NSN or part # through parttarget.
http://www.parttarget.com/
Zed254
466
S. Hampton Roads, VA
tbearatkin
24
SouthWestTennessee
I used a set of magnetic lights and attached them to the top of the tailgate of the trailer. Worked fine and did not fall off for the four hour trip back home.
djglover7
Central Texas
Wheel adapters to go from M1102 8x6.5 to GM 8x180mm.
I am getting ready to purchase wheel adapters to go from M1102 8x6.5 to GM 8x180mm.
Question I have is; what is the M1102 hub center ring diameter? I think it is supposed to be 126.1mm.
Dennis in Texas
Skinner23
SC
I used the magnetic ones about a week ago on mine. I let the tailgate down and used the little swing latches (which aren’t aluminum) that lock the tailgate closed to stick them on. Worked perfect!
djglover7
Central Texas
Done deal.
Done deal. Let the mods begin. First thing is to get 8x6.5 to 8x180mm wheel adapters. Does anyone know about the adapters needing to be "hub centric" ?
djglover7
Central Texas
You could just shop around for older wheels: I used 2000 GMC van wheels..... https://www.steelsoldiers.com/showthread.php?181242-M116A3-with-2000-GMC-1-Ton-Van-Wheels
My 'new' wheels and tires eventually made it to my M1101.
I want the wheels to match my 2016 Silverado 2500 4x4. They are 8x180mm (and I have two complete sets, 8 wheels).
The benefit is to have all wheels match when I am way out nowhere. I can can carry two spares and be rather certain that a single wheel/tire failure will not start a meltdown.
