Which side of Hutchinson 3-piece runflat faces out?
Awesomeness
1,519
Orlando, FL
These Hutchinson 3-piece runflats are asymmetric. The one side has a 1-2" nose on the center, and the other side is basically flat. Which way does that nose face? (I'm not talking about the additional rubber rings.)
HUTCHINSON THREE PIECE 3PC MRAP CRF COMPOSITE RUNFLAT 395-85 R20 BEADLOCK INSERT - 5.jpgHUTCHINSON THREE PIECE 3PC MRAP CRF COMPOSITE RUNFLAT 395-85 R20 BEADLOCK INSERT - 3.jpgHUTCHINSON THREE PIECE 3PC MRAP CRF COMPOSITE RUNFLAT 395-85 R20 BEADLOCK INSERT - 2.jpg
simp5782
Feo, Fuerte y Formal
9,485
Mason, TN
That little ridge is on both sides. It doesnt matter how it goes in. Even the older 3 pieces have that little jut out. The same thing as the rubber ones
Awesomeness
1,519
Orlando, FL
It's not even. When laying on one side, the large diameter of the runflat basically sits flush to the ground. When laying on the other side, it's up about 2".
simp5782
9,485
Mason, TN
Mine are even spaced on both sides. More than likely they were for the aluminum RG31 wheels. I believe the lip went towards the wheel face on the caiman aluminum wheels
Awesomeness
1,519
Orlando, FL
By "toward the wheel face", am I understanding correctly that the long nose would face inward toward the axle?
simp5782
9,485
Mason, TN
No. The wheel face for your outer part of the wheel you remove to remove the tire. The nose will face away from the truck on a LMTV wheel
Do you have the older LMTV wheel or the accuride wheels?
Awesomeness
1,519
Orlando, FL
Thanks. How do I tell the wheels apart?
simp5782
9,485
Mason, TN
Accurides will have a small hole in the area where the lug nuts go thru. They are also only tapered on one side. Being you have an old LMTV it is probably the standard wheel. The 4 wheels together are the standard wheels
There is a new type of aluminum wheel that is tapered and will fit a LMTV as well. They are starting to show up. Shown below
Awesomeness
1,519
Orlando, FL
What's the torque for the nuts that hold the two halves of the rim together? I can't find it in the TM.
