M101A2 Wheels
Jw370
Illinois
Hello All
Does anyone happen to know what the backspacing is on the 8lug 16x6.5 wheels are? I read that it may be 4.25 but i am having an awful time finding a spare wheel. I am trying to keep the same 235/85/16 on the spare.
porkysplace
1,493
mid- michigan
They are the same wheels as a M1008 CUCV , shouldn't be hard to find . Post a want ad in the parts wanted section of the classifieds ,it's free.
8 on 6.5" bolt circle, center hub diameter 4.50", 9/16-18unf studs.
[h=1]M101a2 wheels same as m1008?[/h]
juanprado
2,922
Metairie/La (N'awlins)
should be very easy to find in a junkyard. Look for any 70-80's 8 lug wheels for Chevy/Gmc 3/4 20 series & 1 ton 30 series trucks or vans. All the same till they switched to metric studs and lugs. Metric will not work.
Also dodge will be the same. Difference on a dodge is the hub circle will be bigger but makes no difference as these are lug centric rims not hub so the inner opening wider does not impact anything and is a very small difference.
These are also very common in white or steel wagon wheels for boat trailers/utility trailers with 8 lugs.
Jw370
Illinois
I found these or Craigslist, they should work out just fine? Thanks for all the great information. I went through the entire M101A2 specs and couldnt find the info anywhere
1994-2002 Dodge Ram 2500 & 3500 - 2wd & 4wd
Factory 16x6.5 Wheel Offset = +19 mm - Back Space = 4.50" Inches
gringeltaube
Staff Member
2,523
Montevideo/Uruguay
