Perkman87
- 2
- 6
- Fort Lauderdale FL
Had as friend swap out the ECM to a newer version of the S3 after his truck was eating glow plugs. Ended up getting it back to my shop, since the install of the S3 / and multiple S3s on my end I am coming up with a weird one.
Friend swapped out the Glowplugs/ s3 as it ate them in 200 miles! ( swelling )
Since the install of new GPs and S3 we have a no start situation. No Clicking / No dash lights / ( still have operating lights )
I have already checked grounds / Run through the TM.
S3 is putting out 24 volts but when I trace it to the Wait light at connection 571 Still 24 volts / once I hook up the wait light to 27L it goes down to 6 volts / also 6 volts at the main fusible end links behind dash.
I already tested the starter, and it fires off when I send signal. I can add a lead from alternator main feed to 27L and I get gauges to operate, but no ECM chatter or wait lights.
TM is saying replace ECM again, but I just don't see how thats possible. (Yes batteries were unplugged prior to Swap out )
Could I have a potential problem with a body harness? I checked most all connections and they are showing continuity?
Once the power gets to the Wait light / I know it shares the same circuit as the brake light on the dash then power is split out from there to multiple locations.
I ordered new fusible end links today... just because the original ones were in not so fair of shape.
Any thoughts would be nice, been on it for 14 hours so far, and someone throwing in any feedback will keep me sane for a few more hours.
