Is this an M37 water pump pulley?
CombatJack
12
Texas
Found this with some other M37 parts. Looks to be M37 but the number doesn't pull up anything.
Any help is always appreciated!
Anyone care to take a crack at this buggar i found sitting with some M37 parts?? Not M37, I do not believe.
TGP (IL)
35
Metro East IL
Could be for the 100 Amp system option.
That's the only time double pulley is used.
But I'm not sure about the diameter.
Tom
WillWagner
2,730
Monrovia, Ca.
None of those numbers show up anywhere! It looks like you have the same kind of part as the carb I have, it does not exist!
AVLJeeper
Oregon
You probably already have checked but just in case; Is there a chance that’s two single groove pulleys held together by the cosmoline? It sure looks like two M37 pulleys stacked together.
Still odd that the part number doesn’t cross reference. Maybe that’s why it’s NOS surplus? :-D
USAFSS-ColdWarrior
Chaplain
5,835
WOW!
Good call. I think I can agree that this might be TWO stacked and stuck-together pulleys.
One way to be heck this out would be to stick your finger into the hole in the hub. If you feel two "layers" of sheet metal with a gap between them, then our "theory" that they are "twins" would be proven.
Check it out. Then please report your findings, Soldier!
Carry on.
