1998 M1078 A0 Wiring nightmare?
coachgeo
3,462
North of Cincy OH
They are all md3070 trans. ....
Mine isn't. It's an sp3070. If the wiki is wrong someone edit it where it states the MD3070 came about with the A1's.
Point only shooting at is tranny's and the control devices along with the engines sorta evolved together.... so if it was an A1 era tranny as suggested by the wiki then it might as well have had the wtech III that evolved at about same time.... unless the III's did not at all get used with the non computerized engines......
DREDnot
443
Phoenix, AZ
Ive gone blind trying to find the fuel solenoid on the wiring diagram. Which of these terminals needs the 24v jumper to energize it?
Ronmar
7,474
Port angeles wa
Its located at H57 on the schematic. TL29 is ground(has wires numbered 3015 and 3017 attached), TL28 is the power input(has wires 1441 and 54 attached to it). which normally receives 24V from relay K19 and ultimately CB79... You should be able to confirm ground with an ohmmeter once you break the circuit/lift the leads on one side of the solenoid...
DREDnot
443
Phoenix, AZ
Thanks for this. I gotta reprint my wiring diagram bigger so I can read it and find those.
DREDnot
443
Phoenix, AZ
Got a chance yesterday to get the motor fired up. Tried jumping the fuel solenoid but it didn't start. Shot some ether into the filter housing and it fired right up. So, we know the engine at least starts. Now I need to figure out how to get the main harness out from behind the heater assy. so I can see if I can conceivably re-solder the cut wires.
Ronmar
7,474
Port angeles wa
So did the solenoid go clunk when you jumped it? Did you get fuel all the way thru the system like I described back in post #33? If so, it should have started if the lift pump in the governor is pumping fuel while cranking. You can see this with that plug on top of the secondary filter loosened while cranking...
wheelspinner
1,521
North Carolina - FINALLY !
If you're really intent on trying to fix the harness, pull the heater. Its easy and will make a lot more room to work.
DREDnot
443
Phoenix, AZ
The solenoid didnt make any noise. But the primer pump did move fuel.
DREDnot
443
Phoenix, AZ
Im gonna remove the wires and clean the terminals an jump straight to ground and 24v. Ive fashioned a couple HD jumper wires that I was lacking the first try.
Ive studied the Heater removal chore and plan to move that to get at removing the main wire bundle.
DREDnot
443
Phoenix, AZ
Update....got the PDP and its harness removed...Like gutting a water buffalo.
Other than the dash cut, The only other cut was this plug in the passenger footwell.
Donor plug
I removed the wires and cleaned the fuel solenoid contacts and with a clean jump to 24V, got a good clunk out of it...so that's good.
DREDnot
443
Phoenix, AZ
Preparing the battle space and got to wondering what material the wire is??? Stainless? Seems unusually rigid
Suprman
696
Stratford/Connecticut
The wire is pretty stiff. You can try to solder and heat shrink each one. Not alot of slack in the dash to begin with though. You might try to find some similar wire to add in and stagger the repairs so you dont have them all bunched at one spot.
