- 1,504
- 1,169
- TN
Hi Guys, Does the 3116 have a CDR valve?
What is a CDR said:
Crankcase Depression Regulator Valve
or CDR Valve / Diesels. This valve is similar in function to a PCV valve in a gas engine. On a diesel, the CDR valve regulates the amount of pressure or blowby from the crankcase back to the intake thru the turbo.
Is that a picture of your truck? That large breather hose on mine runs straight down the block (inside the frame rail), not out past the shock tower like that. It looks like yours is being crimped by the cab.View attachment 767708
I believe that the crankcase fumes are handled by the thing on top of the secondary fuel filter housing. Not sure how though. I'd like to see how it functions.
