Front Wheel Hub leaking - Looking for resources to fix it!
Where is it coming from? Hub cover, hub cover plug, back side of hub? From the axle housing? There are 2 ctis seals, a grease seal, and rtv seals. More info would help. If the oil is on the back side of the hub, I have found that the ctis seals have failed, and you may also have oil in the ctis system.
Good morning DriverDarrell!
I have been looking for info on front axles/wheels leaking and came across your reply Aernan.
Since this thread didn’t really go anywhere it seems, do you mind steering me in the correct direction if you can?
I have a FMTV 1083A1, year 2000.
The left front wheel is leaking on the inside, and at this point it is hard to tell where exactly from.
I did have both, CTIS and airlines only hand-tight I discovered.
(the left front wheel was also not releasing the front facing brake pad, but I believe this is unrelated)
Could you tell me, or point me in the right direction for replacing seals which could be at fault!?
Thank you,
Andreas
