Gator has a bounce
Ras1
Rockford, illinois
I need some other gator owner input. I have a bounce at full speed. It is more like a harmonic oscillation. I have new tires, my tires are at 6lbs on the front and 8lbs on rear. The bounce is not horrible, but I'm wondering this is normal for 6 wheels or if I need to start digging in to the issue.
Ty! Dave
USAFSS-ColdWarrior
Chaplain
6,095
I have some Gator experience - Civvy @ Cemetery.
They seem to be sprung for off-road conditions more than on-road.
At full throttle across mowed turf grass you could feel the imperfections in the grading of the soil beneath the growth.
HOWEVER, on the cemetery's paved roads, at full throttle with only one or two people and no cargo all three of the Gators we had would indeed set themselves up with some harmonic porpoising. If you carried 100 or more pounds all the way in the back, the oscillations were dampened tremendously. It's kinda like a Deuce with an empty bed versus a ton+ of "schtuph" in the back. They quit bouncing with a load.
That's just my experience. Your results may vary.
Ras1
Rockford, illinois
Thanks much. That was the type of response I was looking for. I will try some ballast. The harmonic bounce isn't bad; just making sure I don't have a hidden problem.
Lionel
24
Baltimore/ MD
Yep, they bounce. The only suspension in the rear is that which is provided by the level of tire inflation. Kind of like riding an old school "hard tail" chopper back in the day.
