Oil pressure gauge fluctuations normal? Video.
paine
23
SE Michigan
https://youtu.be/eJ4JXyveyro
I assume this is normal but because I stress too much I am going to ask you guys anyway!
Performing a maintenance run while it is 90°F and super humid in Michigan today and noticed the oil pressure gauge moving a little without load change. Frequency seems steady along with all the other gauges.
Take a look at the video and let me know if I am just being crazy!
On on the plus side I have my AC set to 70°F and the 803 doesn’t give a 💩!
*** update***
We have some recessed LED lights in the kitchen and when the 3 ton AC compressor starts (with a good hard start Cap. )the lights flicker / turn off then on, I know the MEP just needs a second to catch up and I was hoping the HS Capacitor would remedy this type of stuff!
Is it just normal and I should just live with it?
Zed254
466
S. Hampton Roads, VA
I notice small needle movements in gauges when I energize the gauge lights on my MEP803A. My fuel gauge jiggles a wee bit during running, but is getting better....I suspect a ground problem but have not been able to correct it. You might want to check you ground connections. I suggest you continue to monitor your oil gauge but don't lose too much sleep over it.......yet.
Guyfang
23,349
Burgkunstadt, Germany
This looks like an electrical problem. But if you are worried, get a gauge and hook it up to check it. Sim, easy. Like Zed said, don't lose sleep over it.
paine
23
SE Michigan
Thanks guys, I don’t think I will loose sleep over it but it will bother me until I rectify it the problem.
So you are thinking I have a loose ground at the gauge or elsewhere? Any problem areas to check?
Its been a while since I read the TM, I could start there.
Guyfang
23,349
Start at the sender, and work towards the gauge checking your wire connections. Then look at the gauge holder. Sometimes it's to loose, sometimes it's over tightened. If some of the other gauges also move a bit, check all the gauge grounds. Some are in series, a ground wire run from one gauge to another.
paine
23
SE Michigan
You is a bad donkey, thanks for the ideas!
happy 4th!
