MEP 803A Surging, Not holding frequency
Guyfang
24,068
Burgkunstadt, Germany
something i wanted to explore was the droop adjustment in the manual. Do you think this could have anything to do with what i am experiencing.
Of course. But I would make sure I worked all the wet stacking out before I fooled with the droop. Does it look like someone else has fooled with it? If not, then that the last thing I would check. First fuel supply and then wet stacking.
Light in the Dark
5,933
MA
If you are clearing out some wet stack, get a bottle of seafoam into that tank, and load it down.
Light in the Dark
5,933
MA
So definitely ground that thing before you do anything else. Secondarily, consider running it at almost full load for the entire tank (and seafom) to allow everything to clean up. You will have a better running machine after it, I can almost promise.
Bluejoe
New Jersey
Hello Did you solve this situation? Thanks
Mr4btTahoe
65
Indiana
I never noticed mention of changing the fuel filters and cleaning the pump screens. I would definitely do that.. especially after running it hard with a solvent in the tank.
Otherwise, looks to be running good. Service it out.
