- 6,961
- 2,468
- Montevideo/Uruguay
Agree on that!
I called them and left a message voicing my concerns they are off for the weekend ill see if they call me back next weekI understand the distances and freight charges makes it difficult to resolve. But if they were a half way decent company, they should at least help with the repair cost.
You would be correct i have different style than yours mine sit in the front lip of mine and have more bolts holding it togetherI may be missing something here but my plates go on the inside of the rim and not the outside. Those look like different rims than mine as well if you look at the bolt count.
Not quite sure i understand what your trying to say but the factory deuce rims as well as the 5 ton and fmtv and im sure others that run duals on the back have wheels that are beveled on both sides so as far as making it weaker i dont think it will be an issueDoes not beveled in on both sides make it all a little weak?
Close to going thru I mean.
Just askin.
OKNot quite sure i understand what your trying to say but the factory deuce rims as well as the 5 ton and fmtv and im sure others that run duals on the back have wheels that are beveled on both sides so as far as making it weaker i dont think it will be an issue
