- 439
- 47
- 28
- Blythewood, SOUTH CAROLINA
Got her all patched up or mostly. I at least got it drivable for Ga rally. The stacks make for a pretty awesome sounding M35! The black truck in the picture is the before taken no September 13. I haven't seen a dual 395 attempted so I wanted to try it.I typically use 105 springs and M35 front hangers. The packs themselves are the same height as M35 fronts. It's just the manner in which you hang them. They allow a little better ride as well. Here is a pic of a spring perch on a truck I'm rebobbing. No U bolts were used... not good! They just had bolts to the plates then a top plate on the springs. Oh and while I was tearing it apart I found that the axle gears are welded solid.
