MEP 802A Fix-up Thread
Zed254
467
S. Hampton Roads, VA
CallMeColt
1,633
Wilson County, Texas
Surge Shock from TM 9-2330-202-14&P: 28 PAOZZ 2510010507136 93072 1844-2 .SHOCK ABSORBER,DIRE................ 1 UOC:CT1,SPR,TC1,258,263 So part number is 1844-2, NSN 2510010507136 and they ain't cheap: https://www.crofttrailer.com/1844-2-hydro-act-actuator-damper-shock/ I'm unaware of any substitute at a fair price. Brake Actuator Assembly: https://www.crofttrailer.com/hydro-act-actuators-ta6-ta7-parts-breakdown/
Great links, thank you! I don't think it is bad... I'm willing to bed there is little or no fluid in there. Hasn't been a priority to work on that part of it yet. Road legal was first. Mounting generator is second. Then I'm going to fix up the brake system. These links will be helpful along with the TM's I have collected. :)
CallMeColt
1,633
Generator is all mounted up. Pulls great. I must say that the unit runs much more quiet on this trailer than my other one.
64402726_2789110944492877_5716476298449125376_n.jpg65033409_835148603516879_4756191000555159552_n.jpg
I put the accessory box & the step plate in a different spot. Not sure what to do on the other end yet. Thinking about a fuel tank.
64705678_323113401912153_898971044855939072_n.jpg65090597_442865896504685_1328601816090279936_n.jpg
CallMeColt
1,633
I found a cheap source for the MOV modification. 10 pack for like $6.
Did a bunch of work on the trailer... it's coming along well.
Anyone have a solution for the diesel fill leaking when towing? Mine seems like leak way more than it should. The gasket is there. I really don't like spilling fuel while towing.
Daybreak
2 Star Admiral
772
Va
I found a cheap source for the MOV modification. 10 pack for like $6.Did a bunch of work on the trailer... it's coming along well.Anyone have a solution for the diesel fill leaking when towing? Mine seems like leak way more than it should. The gasket is there. I really don't like spilling fuel while towing.
Howdy,
There are some threads here someplace.
Fuel cap? gasket
Fuel filler neck gasket? gets old and brittle, especially when they used JP8
top of the tank well nut?
fuel level sensor gasket? SAE 5 gasket
fuel float aux fuel pump gasket? SAE 5 gasket
CallMeColt
1,633
Howdy,
Fuel cap? gasket
Fuel level & float gaskets are new & not leaking. I replaced those not long ago to remedy that issue.
Fuel fill neck gasket seemed good to go & not brittle when I removed the tank.
The gasket is on the fuel cap, but, my guess is that's the issue.
I'll do some searching on the thread for what others have found & done. I just have terrible luck when searching.... put the word fuel & all kinds of fuel related stuff comes up, haha. A direct Google search bring up threads on the site though... may try that.
CallMeColt
1,633
Here is a MOV that will work, for a real fair price: https://www.arrow.com/en/products/mov-14d151k/bourns
Edit: Arrow used to give free overnight shipping for any order. Looks like they changed that. Oh well, still a real good price if freight isn't too bad.
They want $12.99 shipping. Usually the big places kill you with small orders. 10 pack I found on the auction site for $5 with 3 day shipping. I can have spares if others end up needing some.
Sgt Jiggins
Potato Peeler
270
NorCal
I was going to offer the same. That's crazy handling costs.
kloppk
3,962
Pepperell, Massachusetts
I just received a dozen more of them to give to S.S. members.
If you need one I'll drop one in the mail to you. Just shoot me a PM with your mailing address.
No charge.
CallMeColt
1,633
No charge.
I appreciate that friend but my 5 pack arrived yesterday. I'm sure others will need some. :)
CallMeColt
1,633
Tinkered a little with the generator today.
Varistors for the MOV mod came in. Installed.
Was pointed out to me that the fuel cap had an open & closed setting... didn't realize that. Removed it & put it where the small arms are a bit tighter inside the cap. Maybe was leaking as it was because it was open. Next tow, I should find out. Hopefully this will keep me from splashing diesel out!
Ground rod kit & hammer for it should be here by Saturday. Got them new for $150 shipped. Best price I found when looking for over a month.
Sgt Jiggins
Potato Peeler
270
NorCal
That video is on time! Nice! Getting ready to do those mods to my MEP-802A myself tomorrow/saturday pending the USPS. Great to see this, hope youtube makes it easy to find for for others query for that info.
SJ/JD
Sgt Jiggins
Potato Peeler
270
NorCal
Colt,
When your tank comes in, I'd like to see that too. I'm in no hurry for that info, but was thinking about it while trying to figure out a decent way to hook up an external tank in my situation. I'd *really* like to have a larger onboard option given all the extra space on the trailer.
Thanks,
SJ/JD
