- 16,790
- 24,135
- Burgkunstadt, Germany
Got a break. At last everyone is gone. I thought about what might have happened. I told you before, the Schmatices don't agree from one sheet to another. But this is what I think happened. The Schmatices show a set of open contacts that were the ground path the we needed to compleat the A9 power circuit. In reality they are closed contacts. They open when K5 is energized. I don't think they opened. Then we had power following that same path, for the fuel pumps. So to be sure, remove the relays from the A5 card, and test them just like you did the K1.
We we were in the SP/relay box before. My first mistake was not having you check out the A5 card for wires, and the second was not having you look at the back of the card. Just to be sure, I will call up Obi Wan again in the morning, on the way to the rally. Won't be able to write what he said til Monday.
