- 433
- 205
- 43
- Lynchburg, VA
Howdy,
While looking at my 802a running the other day, I noticed 2 things: the temp gauge was non-functional (needle at 7 o'clock position) and the coolant bottle was low. Famous last words: the temp gauge "was working last time I fired it up".
I checked the radiator (full) and added a bit more coolant to the bottle. Bottle isn't leaking (that I can tell?). I'm thinking one/combination of 4 things:
1)air bubble from **** somewhere in there
2)the thermostat is bad and not allowing coolant to flow
3)the electronics behind SW6 are bad (which almost worries me as much as #4 below)
4)the pump is toast.
I looked into TM 9-6115-641-10 and TM 9-6115-641-24. With the troubleshooting section of TM 9-6115-641-24 seeming to point to TM 9-2815-252-24. I leafed through TM 9-2815-252-24 and didn't see any more in the troubleshooting section there either.
Before I tear this thing down a bit, I figured I'd ask if there are any common failure points to check.
Thanks,
SJ
Thanks,
SJ
