Kharville
- 1
- 6
- Clinton LA
Why not tell us instead of the look it up?Dot 5 eats "Teflon tape" , Should I type that again?
Teflon tape is a lubricant
You know, ..............pipe threads, fittings, what have you, at 3/4" per foot taper,
It is meant for PIPE
How about PIPE type threads only 3/4 inches long?
Teflon is a lubricant.
Teflon tape is necessary on fittings like Swagelok stainless steel fittings because
THAT metal DOES NOT squash like ferrous fittings................
Teflon tape comes in many flavors. Some tape from Swagelok is good, others too.
What does the TM say to use?
There is many threads on what is the best stuff to use.
Look up what was used by the OEM on the bottom of your fuel booster pump. That stuff will not EVER leak. I can not say one would ever to be able to get it off again but it will never leak.
Same stuff used on pipe to lube and seal threads by 1954 plumbers.
Like in my kitchen drains.
Look it up.
