KLChurch
- 2
- 0
- Montgomery/TX
Fixed the wire and ready to start. J5 has continuity now.
Kris
Kris
Regardless of your rank, you've displayed tenacity in the trenches reviving a flat-lined MEP-004! Good job you're almost home.Oh wow I'm a Colonel Now. This is great because I'm a Neophyte.
Kris
Take care of bizness partner! When you are ready, we can go farther. Hope the well problem isn't anything tough.Ok,
Will create a new thread.
Just had a new problem. My water well went dry.
So got to find out why.
Thanks so much for the help so far.
Kris
I would think so. There are about 1 million part numbers for that meter.So just to ask one more question.
Do you think the Stewart warner hour gage is original?
Kris
I’m having a similar problem on my Mep 006a. No fault indicator lights working and not getting fuel to engine. It will turn over good, but of course no start up. It won’t work in battle override either.Take a wire, go from the other terminal, where wire number P55X is hooked to the IP. Connect the wire there, and connect the other end to a good ground. Try starting again.
