Mustangsud
- 216
- 43
- Aubrey, TX (North DFW Metro)
Some info on the pics. The pic on the left is the 40 amp 3 ph input into distribution box. The second pic is a 120 10amp 1ph outlet on the distribution box. The third pic is a 208 3 ph power receptacle on a 18,000 btu AC unit.
I have have several other items, such as a water pumping unit that take the same connector as the 40 amp on the distribution box. I have various gen sets 5-30kw, all MEP’s
Thanks for for the Help!
The model is M40 A/PAnother place to find that info, on at least the older sets is the -34 manual, if they break out the wire harnesses. The repair info of the harness includes the wire number, wire size and connectors, by part number. Then you look up the part by manufacturer, and normally they have a list of connectors and plugs. The MEP-002A up to the MEP-007A all have this info in the -34 TM.
Edit: I you give me the model numbers of the D-Boxes, I might have to TM's for them.
