cshowerton
- 1
- 3
- Weatherford, TX
MEP-005A in Texas little bit of HELP
Gentlemen
Just recently got a MEP-005A and it is pretty clean. I have two issues that I need some help with... The watt transducer seems to have leaked out all of the gell that the windings are supposed to be covered in... Is the Watt transducer bad? Should I get a new one? I found one on oshkosh for 300 is this a good deal?
Second... the motor wants to fire but I cant get fuel to it... I can get fuel to the injector pump but I can not get it to pump fuel... I have not taken it off, just taken the top off and made sure the springs were moving... I am not confident in taking the pump off...
I have read many post on here about this and I think I have a good grasp on the motor issue, wouldn't mind any more tips but I definitely need help on the watt transducer... What does it do and what might have caused this to go bad? I just dont want to spend the money on a new one and then burn it up if there is another issue.
Thank you for your help.
Gentlemen
