- 1,199
- 455
- 83
- Spartanburg,SC
This shouldn't happen if your PPV valve is working properly. You probably have a leak somewhere else also. I have a used plunger if you want it. Also if you replace the valve with a different unit, verify that it is a 3 or 4 way valve. A two-way won't bleed off the air.then bleeds the wet tank completely when parked
