johan77
- 47
- 28
- limburg belgium
hi guys,
update on the m275 tractor brakes...airpack rebuild, master cylinder rebuild (this one was in fairly good shape). I connected everything back in place, filled the master cylinder with the proper brake fluid, than i bled the airpack first (without having air pressure), after that i run the engine untill air presssure was build up. (little above 90psi) and started bleeding on the wheels with the help of an assistant. (the airpack i did myself since it was easy to pull on the brake pedal from underneath the truck.)
good thing is that now when there is air pressure the truck is still rolling, the brakes are not applied, BUT i have no brakes at all, i can push the pedal to the floor with very little or no resistance, when released the pedal is also coming back to its position faster than the piston in the m/c.
Is there still air inside somewhere ? with the engine off, air pressure at 90psi and pressing the pedal you can hear a surging sound from underneath, i think in the airpack (the piston rod inside the airpack is moving because the large spring is making some noise).
the pedal is not spongy , you can go all the way to the floor...
help......
help......
