Iceman3005
- 97
- 28
- Holt, MI
Ericsmilitary had some others ones for 14.50, but they where out of stock. Oh well.
Sent from my SM-G975U using Tapatalk
https://gemplers.com/products/large-bore-to-standard-bore-adapter adaptersSimp5782 I need 6 of those valve stems. Also do you have a link to the small bore adapter?
I use the standard budd lug nuts used on m39 m809 and m939 series trucks. The m39 and 809 use shorter studs than the 939 series trucks which is why they use the necked lug nutDo you guys recommend running the lug nuts mentioned even for 939 series trucks? I have my HEMTT wheels back from powdercoat and hope to tackle this job sometime in the next month or so.
You don't have thimbles on the back?I only bought the necked lugs for front axle. Just going to reuse the lug nuts on the rears.
The square head lug nuts on the inside dual are called thimbles. The outside lug nuts you remove holding the outer wheel on will not work on the inner stud. Only the thimbles will. Not recommended to run thimbles as a lug nut replacement on super singlesThimbles?
