Philratcliffe
- 9
- 18
- Florida
I’m looking for 20-25 kw single phase 240 generator. There are two I like and want to buy one of them just would like a little feedback and your opinions
http://www.abrahamindustrial.com/buy/category.asp?id=1
The first two on the page are 25kw the John Deere 2.9L turbo three cyl powered unit is 04 with just over 1,000 hours. I look at the mechanical governor vs the second 25kw which is an 2014 with only 95hours and powered by a 4 cyl Kubota non wet sleeve engine. I like the wet sleeve as I don’t much trust the machine shops down here in Colombia. It has an electronic governor. Which will be less problematic or is the electronic so reliable it shouldn’t be a consideration?
Will a naturally aspirated engine usually go more hours than a turbo Diesel engine?
Also is a four cylinder engine with a smaller lighter piston going to live longer than a turbo engine with three larger heavier pistons.
Here is the kicker. The forth genset on the page is a 30 kw kohler with a three cyl 2.9 John Deere engine also it’s a different engine number but its rated at the same hp as the engine in the 25kw. I’m wondering if has the same fuel consumption as the 25kw until it exceeds 25kw loads??
Please take a look at the specs of the three and give your opinion as to the pros and cons of each unit. The tier rating makes no difference here in colombia I know some of you guys deal with generators on a daily basis!
I looked at aurora generators. That’s where I got pricing on new units. The hardy generator web page is down for some reason.
These units I’m looking at are about 5k less than a comparable new unit with sound enclosure
How often should the injectors be service and cleaned? Thanks in advance for any info...
