Just a short update:
We had some issues with video taping this - so Kris and his friend are trying to get better videos while we are doing this
On the first test we had no Voltage/Hz indication on Front Panel
Selector Switch is currently set to L1-L2 but during Field Flash Kris got only 100VAC but we should see 208VAC between two Phases
The DMM showed 0V during the entire test indicating that we are not getting any High Voltage at all to the H Side of T2
This we will now further investigate - because both H1 and H2 are wired directly into the reconnection board between T8 L2 and T9 L3
I asked Kris to set Selector Switch to L2-L3 for the next test and to hook up the DMM in AC Volts setting to H Side of T2
This connection goes through P/J13 and I checked J13 when I had the A11 here and it is good. However, I have no clue of what P13 (mating female connector in Genset) looks like or if the wires from P13 to reconnection board are toast from the original T2 failure
We will also check the 120VAC Power to T3 in A11 via Rheostat R2 as one side of the Rheostat connects directly to the reconnection board T9 L3 as well. The other leg of T3 connects directly to the reconnection board T12 Lo
Only other scenario at this point is that the field flash circuit on the currently installed VRBoard is not working right, this is/was not part of the A11 bench tests I performed here, but we need to check for proper High Voltages on the primaries on T1 and T3 first
I will post the next update once we got through the two tests on T2 and T3 and I have proper video to go with it
Started up the gen.
No volts and no HZ.
Been talking to Peter and we going to make some tests.
The good thing so far is no smoke
Kris
