- 3,582
- 3,490
- Brooklyn, NY
So, I need power for my 24V back-up camera, and I want it to turn on when vehicle is running and turn off when I stop the engine.
Which wire is live during the drive? Is it safe to run a "Y" connector through that wire to a relay that will turn on and off when I kill the engine?
My desire is to run a relay to turn its own 24 Volt circuit that will power my camera, CB/SSB radio, and double DIN vehicle radio. When the vehicle is on, I want the relay to activate, and when I kill the engine I want the relay to deactivate. I'm hoping a 15 amp circuit will be enough. I also have a full time power inverter for 12 Volts, so I might want to run 2 relays.
I need to know which wire to use, and I need to know if using that wire is safe. I also guess I need to know how many amps the "Y" connector needs to be rated for, or what gauge wires it should have.
Thanks,
T
Thanks,
T
