- 3,871
- 497
- 83
- Gray Court SC
Need someone who is a wizard on hydraulics to help me figure out why my wrecker is working but not correctly.
Holey sentence Batman......... what the hayel did he just try to explain with those words. lol....
First problem the primary selector valves do absolutely nothing per operation manual you put selector valve on crane and only crane works put valve on wrecker and only wrecker works they both work no matter valve position....
ahhhhhh ok. on the much more simple manifold of the FMTV hydraulics....... a few folk have had to rebuild/replace a valve such as the raise/lower valve of spare tire cause it did not work. maybe its that...... would be nice and simple if so? hope for you that is the case. What about a line installed in wrong place allowing a check valve to be bypassed that would prevent what is occurring in your situation. folk have run across quick improper re-assembly of where hose install prior to auctions too.No matter what position those valve's are in, everything operates.
One can send really large files for free with google. It is called google drive. You and the reciepiant must have google but that is only limitation I have seen.View attachment 778443
Ken, I have the entire air, electrical and hydraulics schematics combined into a single file. I'm going to try and upload them
Edit: The whole file was 33 M and too big to upload, so I culled it down to just the two pages on the Wrecker Hydraulics
