dcowan
- 31
- 18
- Rogersville, MO
I have a 1991 M936A2 that I recently acquired. I bought it knowing it had an issue running correctly. It will start only when given a little accelerator. It will only run from about 800 rpm up. From there it seems to run fine. Below that it stumbles and dies. If you let it idle down to about 800-1000 and then hit the accelerator it will stumble and die. It is usually then really hard to start after it dies this way. I have read many posts on this site that have helped me greatly to get things in better order but still have the same issue. Here is what I've done.
One thing I have noticed is everything I have taken off or apart is just incredibly varnished up. Carb cleaner will clean it up but only with some work.
I'm running out of things to try. Only thing I know to try now is injector pump adjustment and or fuel injectors. Those are beyond my knowledge. Does anyone have any ideas?
- Drained fuel Driver Side tank - It was horrible, like varnish
- Cleaned 1" of "tar" out of tank using E85 (this worked amazingly well) - Ended up with 7.5 gallons of what looks like road tar
- Replaced fuel filters - they were horrible. The spin on was rusted and pitted inside and had varnish in it
- Checked air filter it was ok
- Still same issue
- Replaced Injector Lift pump - old one was leaking when hand pumped
- Replaced injector pump check valve
- Still same issue
- Ran fuel line directly from Lift pump into fuel tank bypassing all the old lines / switches and big filter
- Still same issue
