- 16,880
- 24,444
- Burgkunstadt, Germany
Indeed!!!!!!!!!!!!!!!!!!! Got to have a positive mind set here!
This shows what happens when the starter is bigger then the Ampacity of your Batterie. Batteries in Series are more susceptible to explosion especially when the ampacity and charge level are not equal .........Peter convinced me that my batteries do not have enough cranking amps. (500 and 600)
They can fail prematurely because of the starter draw.
Also they are not equivalent of each other. Possible explosion of one of them.
So I have found some commercial Napa batteries that has 1400 cranking amps and will install.
They are not cheap but very close to price of regular 750 cranking amp non commercial batteries.
Kris
Murphy is not a friend of Peter.
Let me explain about Murphy's Law. "What can go wrong will go wrong"
In research mostly everything goes wrong. Until a success. Then the project is over. I have been in research since the early 70s
So I have so been acquainted with Murphy. So much he has become a friend. A friend that you don't want, but when he laughs at you he is in a way telling you "you screwed up"
How many friends actually tell you "you screwed up"
Kris
This shows what happens when the starter is bigger then the Ampacity of your Batterie. Batteries in Series are more susceptible to explosion especially when the ampacity and charge level’s are not equal ........
With greetings from Murphy.....
