Anyone interested in heavier duty hydraulic head button retaining clips?
rustystud
2,725
Woodinville, Washington
Yeah. I believe now after tearing into all these pumps you had the correct solution all along. Unless I had actually seen it on several pumps I would not have believed the plunger could stick like that. Now I know better. I should have listened to your years of experience here "Floridianson" ! The clearances on the plunger shaft are so tight it will create a "pop" when pulled out of it's bore. According to my machinist friend that means it was "hand honed" together. Just another reason to keep good fuel filters on the deuce. Any bit of garbage getting on the shaft will score it up and it will not seal properly and start to leak and lose pressure.
Floridianson
2,487
Interlachen Fl.
The problem has been talked about since I joined SS. I don't remember who ( some of the older members ) that first talked about the varnish / trash but it can be a problem on the plunger/fuel control. Guess it's just the luck of the draw. I have had about 12 Deuces since 06 and some sat for long periods and no problems with the button on any of them. They say if your not good you better be lucky so guess I am lucky but I do keep a Ambac rebuilt head around for that unlucky day. I have also always run some store bought system cleaner/lube in everything. I had a Deuce first but give me a 809 series truck.
Was thinking and I bet 98% of what I post could be googled or I read it here on SS and just passing it along. Maybe just a couple of tricks or Tec tips but that's it. Getting to old to remember what I had for dinner last night so think I will just read more here and post a lot less.
rustystud
2,725
Hey ! You've got a lot of knowledge to share ! Don't let age get you down ! Your only as old as your mind thinks you are ! Since I cannot remember how old I am most of the time I lean towards the young side ! :grin:
doghead
4 Star General /Moderator
1,172
Any updates on progress?
DavidWymore
164
El Centro, CA
Status is still the same. Still on my desk waiting for play-around time. Current work situations don't look promising but I'll see if I can make some time.
Keep reminding me.
