- 1,834
- 968
- Paris KY
I'm planning on adding an oil temperature gauge to my custom gauge panel for my P400/700R4 build. All my gauges will be mechanical, so the gauge I purchased is the Autometer 5441 with a thermocouple line which runs from the thermo-bulb end to the gauge. The bulb has to actually be immersed in the oil to read properly. The bulb end of the thermocouple is a 1/2" NPT fitting, which is the same size as the oil inlet/outlet lines above the stock oil filter that run to the radiator cooler. It will be an easy task to simply plumb-in a 1/2" NPT Tee for the bulb fitting at this location. Problem is, I cannot figure out which line is the pressure line and which is the return line. I want to measure the oil temperature at the pressure line, not after the oil has been cooled at the radiator and returned to the engine. I have been through the TMs but cannot figure out which is which. Does anybody have a clue? No guesses please. I need to get this right the first time.
Thanks in advance for your help.
