coachgeo
- 3,404
- North of Cincy OH
Previous post placed in another thread...... moving here to not hijack the other.
Pulling whole hub and shafts as a single assembly should save time..... Yet like everything there is advantage and disadvantages. Doing it the more typical way by disassembly of each front hub opens opportunity to swap out seals. etc. Thus at some point you will end up removing the hubs for this task anyway..... so why repeat labor if you can avoid it. Advantage is it may be faster and if your in the field or in a time crunch and just need to get that 3rd out (which was my case)....... this method may be better.
Look forward to additional imput others may have
PS- there is numerous threads on swapping 3rd by what has become the traditional way (disassembly of each hub to access shaft) . One of the better threads on this is Pointman's located at:
https://www.steelsoldiers.com/showthread.php?180732-HIGH-SPEED-GEAR-SWAP-With-Photos-1995-A-0
coachgeo said:for quick install of highspeed 3rd in front axle (mostly so can get stock one/core out and ready for pickup asap) do ya'll think you could remove 4 bolts above and below king pin? on backside ... and then slide whole thing; axle and all outward so can swap the 3rd??? or will there be something that will stop the whole thing with axle attached from sliding out enough?
Well, now that’s an interesting thought.
Based on my time shimming my LMTV king pins and looking at the TM’s, it should work.
It seems that the front axle shaft is a floater like the rear, only with a knuckle in the middle.
So, the four king pin bolts are tough, lots of torque. Even with the brake drum removed everything is HEAVY. You’ll have to pull air brake and CTIS hoses as well as the tie rod and drag link.
Then you’d have to start the axle shaft in the third member and into the knuckle on assembly.
If you had a cradle for the knuckle to help support and align, I’d say it should work. And it’d save many hours of work.
On the other hand, you’d miss the fun of replacing a bunch of seals and re-shimming the spider gears...
