My M925 is "missing" some rear dogbones...???
mikev
73
Culleoka, TN
Hello All,
After reading horror stories of self-destructing dogbone bushings, I checked my rear axles.
There are no top dogbones on the driver side of my 5 ton. No axle u-bolts, dogbone mount, nothing...??? Right side axles have the upper dogbones and corresponding axle mounts. Both rear axles have the lower dogbones (all four of them).
My truck is a 1986 M925 (A-Zero) with nearly 40k miles. It has not gone thru a "rebuild". I bought it from a farmer in Ohio who used it as a water truck for his crops.
The paint where the missing dogbones would be tightened is perfect, meaning no signs of them ever being installed...
Any ideas Simp and others???
Thanks.
Mike
simp5782
Feo, Fuerte y Formal
9,361
Mason, TN
Torque rods are only on the passengers side of the truck. They will not fit in the drivers side due to the pumpkin offset of the 5 ton rockwell. Some walking beam systems have drivers side torque rods which is why the bogey has the holes behind the springs.
How your setup looks like you say it does is perfectly normal.
mikev
73
Culleoka, TN
I did notice the pumpkin offset to the driver side and thought "pretty tight fit there for left, upper dogbones"...
As usual, you knew the answer Simp! Are M939 series cargo trucks like mine?
Again thanks and "relieved" I'm not missing suspension parts...
