ill1cit
- 0
- 1
- Somerset Ky
Hey guys, I went to start the Hmmwv this morning and I noticed a whining noise so I shut it back off. To my surprise when I shut it off the starter is staying on. The only way to shut it off was disconnecting the battery cables. With the ignition switch off the starter comes back on as soon as I connect the battery cables again.
I bought it 8 months ago and the PO had just replaced the starter with a rebuilt one. It would occasionally make a grinding sound when starting it after the engine was hot when starting, but that cleared up after I installed a grounding harness several months ago. Also I put a guard dawg keyless ignition system in it several months ago.
My question is, is the rebuilt starter toast or is there something else that could cause this? I’m not home at the moment but before I left I disconnected the 3 wires on the back of the ignition switch but still left the keyless module connected and the starter still comes on when I connect the battery cables. When I get home I’m going to completely remove the keyless module to see if it’s the problem or not.
Any suggestions or anything I need to check? Thanks.
