montaillou
845
W.WA
I had to go check mine. I have the same setup as you - spring (dual) mount at the front of the bed, and then 3 bolted mounts going back the frame.
Yep, visited the mechanic today to drop off a part and talk him into doing more work.
When I got there, he was redoing some air lines and told me he just broke a fuel line. I let him know it's ok, and he can replace any old lines with upgraded lines as necessary. I'm not gonna nit-pic a professional poking around a 50 y.o. engine bay, if he bumps something and it breaks, it deserves to be replaced.
I think I talked him into mounting the second fuel tank, just the mounting though, I'll handle the connections later.
It's funny he kinda doesn't want to work on it, because he runs a shop, but I can also tell he's enjoying working on it. He won't trust any of his younger mechanics to work on it.
jeffhuey1n
SMSgt, USAF (Ret.)
1,580
Laramie County, Wyoming
I lucked out and got a top of the line sand blasting cabinet. I can put most parts I can remove from the trucks. I also have a small Craftsman portable blaster. What a mess! I cleaned three parts and stopped. I’m going to come up with a better idea. I’m leaning towards a wooden framed structure with heave duty plastic wrapped around. Call it a temporary oversized blast cabinet. The only thing I have to buy is a set of gloves from Harbor freight.
I wasn't necessarily married to the Harbor Freight brand, I just meant a "portable" blaster. There may be options of a better quality. I can see a respirator mask, but a full body suit? I'm surprised that's necessary.
You're right though, if I can find a shop with a big cabinet for a reasonable price, I'd rather let them do it and save myself the hassle.
montaillou
845
W.WA
Walnut husks are supposed to be great media (I hear). No fuss disposal. Don't know where you get them though.
You can find them (among other places) at Harbor Freight, at $1/lb. Home Depot also sells it. Probably hunt around and get a better price if you buy a bigger quantity (keep in mind, it will rot if it's not protected) from somewhere.
Another Ahab
4,721
Alexandria, VA
That seems "pricey".
It's making me think of collecting hulls off of neighborhood trees for selling...
:idea::mrgreen:
USAFSS-ColdWarrior
Chaplain
6,088
:idea::mrgreen:
A friend here in San Angelo runs a multi-generational family Pecan business covering central and west Texas - everything from nurserymen to orchards to harvesting to processing. He's shared that they make as much on the byproducts of the shelling operation as they do on the pecan "meat". Besides blasting media the crushed pecan shells can also be made into a pressed-wood product that sculptors apparently love to carve.
Another Ahab
4,721
Alexandria, VA
Every tree is worth more alive than dead: maybe cutting them down is not a real good idea, you know?
Play the cards right, and money DOES grow on trees!
Ajax MD
1,424
Mayo, MD
Play the cards right, and money DOES grow in trees!
The trees don't get cut down to harvest the nuts. A front-end loader with a special arm attaches to the tree and vibrates the h--- out of it, shaking the nuts free.
Edit: Ok, not a front loader, but you get the idea:
https://youtu.be/nahFysX0X4I?t=135
jeffhuey1n
SMSgt, USAF (Ret.)
1,580
I use a sand blasting media that Menard’s sells. It not very expensive and it strips the paint, rust and everything else that sticks to metal. The sand blaster cabinet was sitting in a drive way with a for sale sign on it. $100.00 got a complete system.
