- 1,081
- 1,972
- WOBURN. MA.
The story and sorry for the length. Water got into my control box as the glow would flash now and then driving along and sometime the glow light would be dim while driving. So I pull the control box and open it to find a little water in it. I replaced the control box, Installed new glow plugs most were dead (open).
When trying to start the truck put the key switch in run and the starter would crank (switch in run not start) and no glow light. New switch is wired correctly. Swapped out the key switch for a new M998 reg switch and same issue. The engine harness was not in good shape so picked up a new harness and today it was installed.
Same issue the starter engages on run mode. Disconnected the starter trigger wire just to test and when the key switch is put to run the glow light does not come on. I even replaced the glow plug unit that screws into the coolant port. I am at my wits end on this. Any help would be greatly appreciated. Very frustrating.
Regards
Mark
Regards
Mark
