- 17,471
- 25,830
- Burgkunstadt, Germany
Thanky Ray!
That should be the droop adjustment. The -34 TM has good info about the IP, and Droop adjustment, if I remember right. For some reason, lots of folks just HAVE to fool with the droop adjustment. Most never even read up what its supposed to do, just turn it. Give it a shot, and see if it works. While you are in the IP, pull the screen and make sure its clean. Look in the -34 TM, Figure 3-21, item 57. Normally, if this is dirty, EVERYTHING was dirty, at one time. Its an often forgotten filter, and when its plugged, its a head scratch er. No one remembers it.
