I have joined the club ! And yes I have lost my mine !
coachgeo
3,404
North of Cincy OH
Installing a heater in the RV box. Will let you all know how it goes.
Its a Chine's (so who knows if it works ? ) diesel .
There is a fellow on youtube who has done extensive testing and tweaking of these... search it out... very informative.
https://www.youtube.com/watch?v=tvwmU_CcmGI&list=PLne7MoW21Rk01DYGGfOqIbYt6H1ZFSFks
another hint.... a fellow somehow (maybe an exhaust cut out valve?) set his up to redirected his exhaust from the unit into a little radiator to use as a coolant heat exchanger to help warm engine coolant while heating cabin with it. OR maybe he just redirected cabin heat with a duct to the exchanger?? but I like the exhaust idea better..... heat two things with one.
1951M1078
185
Glendale,AZ
[FONT=&quot]Been mostly sitting on my ass. But working on a lot of system's that need to be installed on M/RV.[/FONT]
[FONT=&quot]At Overland Expo 2019 I found I need to run the Tank-less water heater to long (wasting "Water" ) to get it hot ?[/FONT]
[FONT=&quot]That will not work with only 42 gal on the truck. Did some testing and found I needed to run about 1 1/2 to 2 1/4 gals to get hot water.[/FONT]
[FONT=&quot]Played with running a pump to keep the tank hot but the pumps don't like 102 deg. water and their is the power loss ?[/FONT]
[FONT=&quot]What I came up with is a SS tank (3 gal.) with a 300 W 24 volt heater for it. It will run off the battery / solar when needed. May even make some kind of timer control-er for turning it on a off ?[/FONT]
[FONT=&quot]Something like on at 7 am and off at 9, then on at 11:30 and off at 1pm then on at 5pm and off at 7pm ? We will see ??
[/FONT]
coachgeo
3,404
North of Cincy OH
...At Overland Expo 2019 I found I need to run the Tank-less water heater to long (wasting "Water" ) to get it hot ?
That will not work with only 42 gal on the truck. ...
they make a loop valve that keeps running same water thru the inline heater until the heater is up to full temperature. Designed specific for RV's. Here is one type..... the technology has grown some since this video. There are many DIY versions too
https://www.youtube.com/watch?v=FBh395UyiaY
Another Ahab
4,445
Alexandria, VA
Even when you're talented and CAN invent a thing that will solve a problem, it can be sweet to discover it's available (ready-made) right off the shelf.
:jumpin::beer:
SausageGuy
35
Kansas City MO
Even some houses have a push button by a sink that you push when you need hot water and it runs a circulation pump for a predetermined time. Then when you open water valve the cold water has been put back in the system and you get the hot water only.
1951M1078
185
Glendale,AZ
Thanks,I looked into that way of doing it.
But it will not work with my system. The heater is between the 2 out lets.One would be cold.
Also the RV had a tank heater. The problem their was the length of the run.
Its more the tank-less,I just added a holding tank.
1951M1078
185
Glendale,AZ
[FONT=&quot]Even after going with the bypass system I am going to still add the 24V heater. [/FONT]
[FONT=&quot]This is the work that was needed to convert the SS air tank to a water heater and 3 gal. tank.
IMG_6570.jpgIMG_6572.jpgIMG_6573.jpgIMG_6574.jpgIMG_6575.jpgIMG_6576.jpgIMG_6577.jpg[/FONT]
FloridaAKM
392
Gainesville, Florida
That is very good work on the adding the 1" thread-o-let & good looking weld. If you had brushed the weld while still hot with a SS wire brush, it would have been as shiny as the rest of the tank. It is just cosmetic, so just an observation, not to detract from your work. I work with pipe welders who TIG ss 316L process pipe on a regular basis & that the way their work looks as it is always exposed.
Another Ahab
4,445
Alexandria, VA
No kidding, that is some good looking work.
Was that hole-saw carbide, did it cut through pretty easy?
1951M1078
185
Glendale,AZ
Thanks.
Just bi-metal and some cutting oil. I even used a battery drill on the low speed setting.
Think its all about the speed of the cut.
1951M1078
185
Glendale,AZ
[FONT=&quot]Today I got to do the first test with the heater on line. Worked great ![/FONT]
[FONT=&quot]This 3 gal. of hot water on line works great.[/FONT]
[FONT=&quot]Next will be a test with the 24V heater in the tank.[/FONT]
[FONT=&quot]But their is a lot of work to do on the Solar system.[/FONT]
Not sure why the flow is better in the system but I will take. What is funny is it is on both sides hot and cold ?
Test power came from my USB outlet with a 5 amp fuse. I didn't test the valve coil for power but no problem.
Will need to reset the water temp. Was a little high for a shower 125+ ? ( line from "Space Balls" TOO HOT ! ) LOL
