MEP-831A Remote Start/Stop
sassriverrat
Georgetown, MD
Has anyone ever tried to put a remote start setup on this- or install an aux (remote) start/stop switch or panel? I would imagine a secondary switch could be spliced into the existing panel- but thinking if this generator was mounted outside of a building or trailer but the start/stop was inside, that would be nice.
I'm looking at the Ini Power IG1000 ASKR-USMC Auto Start Kit but can't find any manuals on it so I'm not sure it's pin out and how I might finagle hooking up the generator to this.
Thanks
witteriedmf
Charles Town/WV
Thanks
TM 10-6115-711-10TECHNICAL MANUAL OPERATOR MANUAL FOR GENERATOR SET, MULTI-FUEL, PORTABLE, 1 KW (NSN 6115-01-612-2549)
good luck finding the manual
synelecpb
point pleasant NJ
Not a awaken a mummy of a thread, but some MEP 831's were wired by the military for remote operation. Mine was one of them. The problem is that they have a 9 pin connector that plugs into something unknown to facilitate that, and some of the wiring was rearranged to (I assume) make that possible. When I first got it, things didn't work properly until I got on this site and explained what was happening - others had seen this arrangement and told me what to do to change it around to standard operation. I left the connector on mine, if you want a picture of it.
fighdeaux
San Francisco, CA
Guyfang,
I would be interested in some info on your setup. I have a MEP 831 that I'm trying to get remote start configured on. Thanks!
FarmingSmallKubota
1,116
Wapakoneta, Ohio
Thanks
The Ini Power unit will not work. They are made to pull the cord on a rebranded 1000 watt yamaha Generator with internal decompression valve. To pull start a 831 with a Yanmar requires the decompression valve to manually be pushed to overcome compression
