M1102 Side Marker LEDs
478
12
Tucson AZ
Hi
I did some searching and even checked the Tm (which only seemed to cover incandescent) and I can’t find what I’m looking for. I have two dead LED side markers on my 1102 and I’m hoping you can direct me to a replacement. Here is a pic for reference.
Zed254
466
S. Hampton Roads, VA
Confirm that the upper left ground screw is making good contact with trailer frame/body. I had similar problem a few weeks ago and that was what was wrong. I've also had to replace a light or two when I couldn't get them to work. If you need to purchase new, Erik's has them, so does Ebay:
Side Clearance Light LED (383-Green Housing) Red Lens, 12446845-2 / 12422973-002
Side Clearance Light LED (383-Green Housing) Amber Lens, 12446845-1 / 12422973-001
OEM: http://www.auroradefensegroup.com/product/marker-lamps/
12
Tucson AZ
Hi
yes the first thing I did was tighten those grounds, test them, and ensure there is voltage at the plug. All tested good so I’m thinking the leds are bad.
that one from eastern surplus is the wrong shape, I would like them to match the rest of the trailer.
DeadParrot
47
oklahoma city, ok
The ones on my M1101 are the round lens LED. Maybe they switched styles at some point.
If you can't find ones that match and you need red ones, maybe buy three of the round ones and swap out the ones on the rear facing triple fixture and use those for the side markers. At least then the sides would match and most folks probably wouldn't notice the rear ones being different.
478
12
Tucson AZ
Ok yes thanks guys. I do know how to find parts on ebay etc I just needed help with the LED part numbers so I could search the correct part. ZED nailed it and I have two new ones incoming from ebay.
Zed254
466
Here's what I found: My 2006 M1101 has Aurora lights....not LED, but the MFG is Aurora. I searched for Aurora Marker Lights and found this link..... http://www.auroradefensegroup.com/product/marker-lamps/
That link shows:
12446845-124V. Amber/Diff. LED Assy/Shell
12446845-224V. Red/Diff. LED Assy/Shell
If you search Erik's you'll find his description calls out LED for these Marker Lights:
https://www.eriksmilitarysurplus.com/sicllile3grh.html
https://eriksmilitarysurplus.com/siclliled3gr.html
BWSabio
Farmingdale, NJ
Hi
I have the same issue as well ... if you were able to resolve your issue would you mind sharing how you did it?
Thank you,
Brett W. Sabio
