Check fuel tank dip tube and its solder joint on the underside. Replace the fuel lines, especially the suction side. Make sure the frame mounted fuel filter (if you have one) is sealed up tight and the square washer is fully seated squarely into the housing, rubber side down, drain valve is fully closed, etc....
Could also be the over-flow valve stuck open on the outlet banjo fitting of the injection pump. You can clamp this hose shut for 60 seconds and release as a field cleaning attempt. Do this several times. This valve should "squeak" when the primer button is pushed if working correctly.
