- 2,651
- 2,141
- Sunman Indiana
Hah, and I thought I was the only one that had that! I think I have some white food grade somewhere around here as well!
Yes. This topic has had it's problems, but I'll add an interesting note. When I first took off my Deuce's wheels they had anti-seize on the lug nuts. I bought this truck right out of Fort Lewis/McCord . No one but the military had touched it. So that means they too used anti-seize on lug nut studs. Just like we did at the transit bases here in Washington. For decades. Lots of anti-seize. Really used a lot of it.@ Jbulach.... whatever works for "them" is fine with me. And whatever I do that they don't like....too bad. I have been using that product for 45 years without any problem. http://www.rtsauto.com/should-you-put-anti-seize-on-your-lug-nuts-or-wheel-bolts/
It's like 1st gen and 2nd gen or maybe 3rd gen and then there is the friction ring or pin detent and then the one key blue tooth. I've got the 2767 that the one with friction ring and 1,00 lbs ft / 1400 lbs ft. And the newest one has the extended anvil and controlled torque that you can dial in 4 different settings.?.Milwaukee's webpage is not very clear in this regard (apples-to-apples comparison of similar model tools).
Just went to search, and there are (at least) 8 models of the 1/2" Impact Wrench:
https://www.milwaukeetool.com/Search#q=m18 fuel 1 2 high torque impact wrench
https://www.homedepot.com/p/Milwauk...ing-Kit-W-One-5-0Ah-Battery-2767-21/306180606Thanks for the informative replies, I bought the new 1/2 inch cordless Milwaukee m Fuel M 18 with the 8,2 battery . pops them right off. its heavy but man does it bust them loose , Cant say thank you enough guys , I was that 225lb fella wanting a young solider B to break them loose when I had a 10 foot cheater bar on them and they SCREAMED when I finally them got them loose. got 20 % off for black Friday 10% Mil discount but it was still 280. for the tool and 105$ for a battery and charger
Well now that we’ve gotten our credentials out there and a little anti-seize all over the place, thanks for the link Ahab!Milwaukee's webpage is not very clear in this regard (apples-to-apples comparison of similar model tools).
Yep, they have different “High Torque” models with torque numbers all over the place!The 1/2" high torque has more power than the 3/4", just saying.
OOPS I stand corrected the NEW one key 3/4" packs more power than the 1/2".
According the Milwaukees site 2864 is the 3/4” drive? Also they do show a 3/4” and 1” model that have more torque than the 1/2”.That’s correct. As long as you get the Milwaukee part # 2864.
Good deal! I may go that route just for the case, and wouldn’t hurt to have another battery anyway. Sure don’t need another charger laying around though!
Don't want any drift to get us all keelhauled or anything, so commenting now back on thread:When working as a young man in the shop I would always reach for my air tools to speed up the job. Now with the cordless I have put away my air tools and ratchet's.
Yeah except all Milwaukee tools are made in Dongguan, ChinaMilwaukee ironView attachment 783494
Yeah, we're pretty much ALL connected worldwide these days.Yeah except all Milwaukee tools are made in Dongguan, China
If this is a repeat sorry but a buddy just got a new Milwaukee Cordless its like 36 volts or more and can generate 1800 ft pounds of torque. The battery life was very good for this type of performance and it retails for 1K$ Milwaukee is marketing it in the Industrial sector, not for trucks!
One thing leads to another. It's a vicious circle. I hope no one makes a battery powered jack.
I just ordered the Milwaukee 2767-21 from Home Depot. Good price and I'm getting tired of dragging the 100' air hose from my shop to the front of the house where I work on my trucks. Plus easier traveling with our RV. No more getting the generator out to run the compressor etc. Now I may have to get a battery powered compressor for airing up tires so I can leave the compressor at home.
