M1078 Build: not a camper nor cargo truck....
Awesomeness
1,518
Orlando, FL
Another difference in the weight is that the TM defines "curb weight" as a weight that is ready-to-roll, with driver, equipment, fuel, MOPP gear, etc. Right away you should be about 1000lb off.
olly hondro
521
tucson AZ
Yes, the "before" weight at the scales confirms what you say. I weighed it in stock configuration, with a second spare tire/wheel, before I started the project. Steer axle = 10,440 lb, drive axle = 6240 lb, gross weight 16, 680 lb.
Thank you for that clarification.
