7 Ton cargo cover and hardware
blhar15
11
Waterloo, IA
I just did the same with a complete 5 ton kit, except the cover, I found the actual cover for the MTVR. Note, the 5 ton series trucks use six staves on each side and the MTVR uses seven, so you need one extra pair. Now, I just need to find another set of the seat backs, as my truck only came with the front set.
JonM934
234
Herriman UTAH
Blhar15, you are correct but maybe we should say you need AT LEAST 7 sets. I see that the bed sides have places for 9 sets and the storage rack behind the cab has places for 8 sets.
blhar15
11
Waterloo, IA
The TM I have for the MK23, 14' bed shows seven on each side. I am sure you end up with more on the longer trucks with the 20' bed.
JonM934
234
Herriman UTAH
I have the regular bed. There are 4 staves per bed side and there are 2 sides on each side. So that is 8 and there is one more in the corner up by the cab end of the bed. So you could put 9 sets of staves in if you wanted to. I think two of the sets are very close and you don't need to double up when they are so close. So 7 sets seems about right.
JonM934
234
Herriman UTAH
I installed the seats but the pins used to attached the seats to the bed sides were missing. I used 1/4 inch bolts instead and they work but it would be better to use 5/16 bolts. Of course, use lock nuts so the bolts don't rattle out.
M813rc
3,270
Near Austin, Texas
I had high hopes some years ago when the MTVR came out that I could finally get a fitted tarp for my ISO bed Marine M813. It was not to be, I measured the 7-ton bed, it was 14' not 15'. :( On the 813, the spare tire and davit are inside the front of the bed, rather than mounted behind the cab.
Not trying to be a know-it-all, but offering some constructive advice - the tarp actually goes the other way around on the truck. The triangular flaps should fold from the front around onto the sides, and the side ones around to the back. This will keep the wind from inflating your tarp as much when you drive, and will keep most of the rain out. ;)
Cheers
JonM934
234
Herriman UTAH
M813rc,
"Not trying to be a know-it-all, but offering some constructive advice - the tarp actually goes the other way around on the truck. The triangular flaps should fold from the front around onto the sides, and the side ones around to the back. This will keep the wind from inflating your tarp as much when you drive, and will keep most of the rain out. "
Yes, I know. I fixed it after I took the photos. Thanks for mentioning it though. It is strange because from the way the tarp is constructed, the seam at the top is the other way. So if you do it the proper way, then the seam at the top is bent because it is sewed the other way.
I have been to Austin my times. My brother, who was a Major in the Air force, lived there. He has passed away now.
M813rc
3,270
Near Austin, Texas
Sorry on the loss of your brother.
Due to stupidity on the part of the then-city council, Bergstrom AFB got closed down and turned into the city airport. Only after the fact did they realize it was a major local employer and was going to cost huge money to turn into a civilian facility.. That's what you get for voting old hippies and street corner flower sellers into office.... :rolleyes:
Cheers
JonM934
234
Herriman UTAH
So I was playing around with the bolt for the cargo bed seats and I found out the correct size for the seat to bed side is 3/8 of an inch. I bought a few pins with the retainer and so now I can take the seats off without tools. Of course, if you need room in the bed, you can fold up the seats to get them out of the way so you don't need to take them off.
