Need Oil Cooler O-rings
chevymike
462
San Diego, CA
Hi all,
I just got my radiator back from being re-cored and I need the O-rings that go on the oil cooler lines that go into the radiator. I looked in the TM and found the part number of 14055585 which seems to be those O-rings but in doing a Google search, it appears these are discontinued and no one has them available.
I would have to assume there is something that cross references to an available part but I have not been able to track that down.
Does anyone know what brand/part number I need to get that is the same item?
Thanks!
cucvrus
10,316
Jonestown Pennsylvania
I would go get some from a automotive parts house. I do it all the time. Nothing special about them. they fit snug on the oil cooler lines and they are good to go. I use green ones when I can find them. Good Luck. I wouldn't sweat the OEM oil O rings. I think Felpro makes them.
chevymike
462
San Diego, CA
Do you have a part number? Most parts stores are totally clueless and I have not been able to track the part down in a different brand.
cucvrus
10,316
Hey they are discontinued. I have a parts friend at the GM dealer that says he has 4 of the OEM 14055585 O rings in stock. He will get back to me when he locates them. Are you interested? I am either way. I wanted to make the offer. They are GM captured parts. It will be a few days. Have a Great Day. I would even use the old ones over if they are not trashed. Good Luck. Wrap it with white paper towel and fire it up. Check for leaks.
chevymike
462
San Diego, CA
No I mean the FelPro part number. I don't need GM ones, I only used that part number as a reference since it is in the TM. I just need new O-rings and don't care who makes them. I want to get this radiator in this weekend so I need to get something from the parts store.
cucvrus
10,316
I would take a trip to a hydraulic shop or a parts store and get an O ring that fits. Do you have an old one. There were 2 do you have just 1 as a sample. Not much special as long as it fits snug on the aluminum line. I don' have a part number. I walk in get one that fits and .50 later it is in service. At one time every new oil cooler line had them. Now I get them sometimes and other times not. That's the best help I can offer. I am still going to grab the ones my friend has. Good Luck. Not much pressure involved here. I have an assortment box of O rings I use also.
Terracoma
13
Albuquerque, NM
I recently installed a new aluminum radiator in one of my M1031's, and opted to purchase new O-rings from NAPA.
The counter help and I settled on two part numbers that very closely match the original O-rings: 727-2111 and 727-2606... After disassembly of the old radiator, I decided that the 2606 O-rings were the best fit.
chevymike
462
San Diego, CA
Perfect, This is exactly the info I was looking for!!!! Will hit up NAPA. Thanks so much!
Terracoma
13
Albuquerque, NM
No problem! They're sold individually by those part numbers, and my local NAPA had them hiding "in the back".
I believe all the oil cooler line O-rings are the same size and same material, so these should also fit where the rubber hoses meet the aluminum tubes on the driver's side, as well... The NAPA O-rings are Buna-N, which are oil resistant and should work fine. As Rick mentioned above, the automotive air conditioning O-rings are also a good fit for this application. The size to look for is something very close to 10mm inside diameter with a 2mm ring thickness.
